Warning: http_response_code(): Calling http_response_code() after header('HTTP/...') has no effect in /var/www/html/libraries/vendor/symfony/error-handler/ErrorHandler.php on line 658
*/public function disconnect(){// Close the connection.if (\is_callable([$this->connection, 'close'])) {$this->connection->close();}parent::disconnect();}
in
/var/www/html/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php
close
(line 318)
in
/var/www/html/libraries/vendor/joomla/database/src/DatabaseDriver.php
disconnect
(line 496)
** @since 2.0.0*/public function __destruct(){$this->disconnect();}/*** Alter database's character set.*
mysqli object is already closed
