Deprecated: Method ReflectionProperty::setAccessible() is deprecated since 8.5, as it has no effect since PHP 8.1 in /var/www/html/plugins/system/falangdriver/falangdriver.php on line 534 log sequence number is in the future,数据文件中页面的LSN(日志序列号)比当前系统的LSN更高 - Bluetooth forum - bluetooth蓝牙技术
Bluetooth & UWB forum
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 service
[ Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 service]
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 帖子作者
离线
管理员
Less更多
感谢您收到 0
2026-02-07 21:28#1118 Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
物理备份一定要先停止mysql.
sudo systemctl stop mysql
错误解决方法:
根据MySQL官方文档,当出现“log sequence number is in the future”错误时,可以尝试使用innodb_force_recovery模式启动,然后导出数据,最后重新初始化数据库并导入。停止服务并强制修复# 1. 立即停止MySQL服务
# 1. 启动MySQL服务
sudo systemctl start mysql
# 2. 使用临时密码登录并修改密码
mysql -u root -p
# 输入临时密码后执行:
ALTER USER 'root'@'localhost' IDENTIFIED BY '你的新密码';
FLUSH PRIVILEGES;
EXIT;
# 3. 使用新密码登录并导入数据
mysql -u root -p < /tmp/mysql_full_backup.sql
# 4. 如果导入过程中出现错误,可以尝试分批导入
mysql -u root -p -e "CREATE DATABASE IF NOT EXISTS btchina;"
mysql -u root -p btrafavi < /tmp/btrafavi_backup.sql
/code][b]验证修复结果[/b][code]
# 1. 检查错误日志
sudo tail -n 50 /var/log/mysql/error.log
# 2. 运行MySQL表检查
mysqlcheck -u root -p --all-databases --check
# 3. 测试问题表
mysql -u root -p -e "USE btchina; SELECT COUNT(*) FROM ff583_session;"
mysql -u root -p -e "USE btchina; SELECT COUNT(*) FROM ff583_scheduler_tasks;"
# 4. 检查InnoDB状态
mysql -u root -p -e "SHOW ENGINE INNODB STATUS\G" | grep -A 20 "LATEST DETECTED DEADLOCK\|LOG"
📚 官方修复流程参考:[url]
[/url]
Deprecated: Method ReflectionProperty::setAccessible() is deprecated since 8.5, as it has no effect since PHP 8.1 in /var/www/html/plugins/system/falangdriver/falangdriver.php on line 100 mysqli object is already closed (500 Whoops, looks like something went wrong.)
