Exploring Partnership Opportunities with rafavi China - Bluetooth forum - bluetooth蓝牙技术
  • Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
    service
    service]
13 Jul 2025 01:13 #296
We believe that our Bluetooth AoA (Angle of Arrival) technology could offer an excellent alternative to UWB technology, providing high-precision real-time tracking for your business. Our solution is capable of achieving centimeter-level accuracy, offering a reliable and scalable option to meet the needs of your water park.Our Solution Overview:
  • Real-Time Positioning: Our system can display the real-time location of each lifeguard on a custom aerial map in the control room, with accurate positioning represented by colored dots.
  • Fast Response Coordination: Upon receiving an incident report, the system can instantly locate the nearest lifeguard, ensuring that reinforcements or equipment are dispatched quickly.
  • Optimized Supervision: We offer a scalable solution that ensures all key areas of the park are covered by lifeguards, offering you full visibility of your staff in real-time.
Key Features of Our Solution:
  • Bluetooth AoA technology for precise location tracking with 0.1-0.5 meter accuracy in both indoor and outdoor environments.
  • Durable, Waterproof Components: Our tags and devices are built to withstand harsh conditions, including water exposure, ensuring their reliability in a water park environment.
  • Easy Integration: Our system is compatible with existing control room systems and can easily be integrated with your DMR radios for full visibility and coordination.
Next Steps and Proposal:We would be happy to explore the feasibility of customizing our solution for your specific needs. Here’s what we can offer:
  • Development Timeline: We can discuss the estimated timeline for customizing the system to fit your park’s requirements, and offer a pilot project to demonstrate the system in action.
  • Hardware & Infrastructure: We will provide details on the hardware required for tracking, integration with existing infrastructure, and system installation.
  • Pricing & Collaboration: Based on your project’s scale, we can provide a detailed proposal, including pricing for a pilot project.
Please let us know if we can schedule a call to discuss further, and we would be happy to explore how we can collaborate on this exciting project!
