Deprecated: Using null as the key parameter for array_key_exists() is deprecated, use an empty string instead in /var/www/html/plugins/system/t4/src/t4/MVC/Router/T4.php on line 388
MEMS microphone design - Bluetooth forum - bluetooth蓝牙技术
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/kunena/src/Route/KunenaRoute.php on line 768
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/kunena/src/Route/KunenaRoute.php on line 781
  • Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
    service
    service]
22 Jul 2025 01:50 #316
The Company has been a leader in technological innovation for 15 years. Specializing in MEMS microphone design, the company excels in audio pickup technology, noise reduction algorithms, and seamless hardware-software integration.
Our products include MEMS microphones and array microphone modules. Key strengths are advanced audio technology, high-quality control, and diverse application adaptability. These features ensure superior acoustic performance.
Would you be interested in exploring a partnership? How can we assist in meeting your business needs?
sale@bluetooth.com.cn
