Deprecated: Using null as the key parameter for array_key_exists() is deprecated, use an empty string instead in /var/www/html/plugins/system/t4/src/t4/MVC/Router/T4.php on line 388
gaming mouse,keyboard and headset - Bluetooth forum - bluetooth蓝牙技术
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/kunena/src/Route/KunenaRoute.php on line 768
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/kunena/src/Route/KunenaRoute.php on line 781
  • Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
    service
    service]
26 Jul 2025 09:01 #354
we are manufacture in gaming mouse,keyboard and headset for 12 years.
DIY is new trend,and distinguished from normal gaming mouse
GT-140. DIY the switch and case,Kindly Examine attached Video:)
1. Support all standard switch TTC,Kailh,Omron....suitable for office and gaming
2. Honeycomb and non-honeycomb is optional
3. Support do your own driver software
4. suitable for office and gaming
GT-ProX DIY different case
1. S for gaming,M for daily use,L for office work,
2. save more advertice fee and easy catch customer eyes.
3. suitable for different size hand,one mouse for whole famaily
4. our private molding,and enjoy the priority Promotional.
5. suitable online and off-line market.
Ask for products list
