Deprecated: Method ReflectionProperty::setAccessible() is deprecated since 8.5, as it has no effect since PHP 8.1 in /var/www/html/plugins/system/falangdriver/falangdriver.php on line 534 mysql完整备份 - Bluetooth forum - bluetooth蓝牙技术
Bluetooth & UWB forum
mysql完整备份
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 service
[ Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 service]
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 Topic Author
Administrator
LessMore
Thank you received: 0
07 Feb 2026 21:35#1119 Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
方案A:彻底停止服务备份(推荐)
# 1. 停止MySQL服务
sudo systemctl stop mysql
# 2. 确认完全停止
sudo systemctl status mysql
# 应该显示:inactive (dead)
# 3. 备份配置文件
sudo tar czf /backup/mysql_config_$(date +%Y%m%d_%H%M%S).tar.gz /etc/mysql/
# 4. 备份数据目录(物理备份)
sudo tar czf /backup/mysql_data_full_$(date +%Y%m%d_%H%M%S).tar.gz /var/lib/mysql/
# 5. 重新启动MySQL
sudo systemctl start mysql
# 6. 验证启动成功
tail -n 10 /var/log/mysql/error.log
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/administrator/components/com_hikashop/classes/address.php on line 571
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/administrator/components/com_hikashop/classes/address.php on line 610
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/administrator/components/com_hikashop/classes/address.php on line 612
¥697.01
No vote
Whatsapp
¥34.85
No vote
Deprecated: Method ReflectionProperty::setAccessible() is deprecated since 8.5, as it has no effect since PHP 8.1 in /var/www/html/plugins/system/falangdriver/falangdriver.php on line 100 mysqli object is already closed (500 Whoops, looks like something went wrong.)
