Deprecated: Method ReflectionProperty::setAccessible() is deprecated since 8.5, as it has no effect since PHP 8.1 in /var/www/html/plugins/system/falangdriver/falangdriver.php on line 534 sqlite3数据库删除 - Bluetooth forum - bluetooth蓝牙技术
Bluetooth & UWB forum
sqlite3数据库删除
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 service
[ Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 service]
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 239 Topic Author
Administrator
LessMore
Thank you received: 0
27 Dec 2025 09:26 - 27 Dec 2025 10:19#966 Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/libraries/CBLib/CB/Legacy/LegacyFoundationFunctions.php on line 189
# 删除现有的数据库文件
rm -f instance/databasename.db
#手动添加
updated_at
列
-- 连接到 SQLite 数据库
sqlite3 instance/database.db
-- 添加 updated_at 列到 users 表
ALTER TABLE users ADD COLUMN updated_at DATETIME;
-- 添加 updated_at 列到其他表(如果需要)
ALTER TABLE websites ADD COLUMN updated_at DATETIME;
ALTER TABLE articles ADD COLUMN updated_at DATETIME;
ALTER TABLE social_platforms ADD COLUMN updated_at DATETIME;
ALTER TABLE settings ADD COLUMN updated_at DATETIME;
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/administrator/components/com_hikashop/classes/address.php on line 571
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/administrator/components/com_hikashop/classes/address.php on line 610
Deprecated: Using null as an array offset is deprecated, use an empty string instead in /var/www/html/administrator/components/com_hikashop/classes/address.php on line 612
¥697.01
No vote
Whatsapp
¥34.85
No vote
Deprecated: Method ReflectionProperty::setAccessible() is deprecated since 8.5, as it has no effect since PHP 8.1 in /var/www/html/plugins/system/falangdriver/falangdriver.php on line 100 mysqli object is already closed (500 Whoops, looks like something went wrong.)
